Refnum for a Notifier Reference Object - "not valid in this application instance"
Maybe it's normal...
Maybe it's because I wasn't looking at those references as closely before.
Maybe I saw it because it was part of my search for a bug...
Maybe it isn't normal.... :o
Maybe I should post a thread and find out why the reference was "not valid in this application instance"
... maybe... just maybe.... I'll learn more stuff.. Maybe for sure... :)
Okay, if you read past that junk above, here's what I observed. I know nothing, hence this thread.
I have a wire which is a cluster of a whole bunch of objects. The objects are basically notifiers. The class contains a reference to the particular notifier.
While debugging the code where all the notifier references simply "disappeared" (I know it does not simply disappear, but it did), I noticed something odd. It just caught my eye.
What is strange and why I ask is because the refnum value is correct. 0x1450 0002
I should have taken a screen capture of the code, but then again, there was not much to see. So I will describe it.
Picture 3 VI's. Ignore all the preceding ones and following ones for now. To the left, there is VI-1, middle VI-2, and to the right VI-3.
Below are the outputs of VI-1 to VI-2 to VI-3. The strange thing is the fact that the refnum is "okay" at the output of VI-3. So, valid, not-valid, then valid again.
<< Am I simply observing something normal? >>
post-2829-0-02326800-1355151707_thumb.pn
Thanks Yair.
Wow.. What a thread.
I am digesting all that info and will post more details into that thread. It is easier to continue the conversation in the original thread.
Cheers!
RayR
