Calling dotNet(C3) code
Hi
I got some C# dlls that I have to use in LabVIEW.
It is written in dotNET 4
It works fine in LV2012, but I shall use it in LV 8.2.1.
When I use it in LV8.2.1 I get the following error.:
Error 1172 occurred at Error calling method VesTest.Common.Utils.SoftwareUpload.Strategies.PhoenixSoftwareUpload.AutoIpDetectingPhoenixSoftwareUploadStrategy.Upload of ObjectId handle:
 0xC9911C4 for obj 0x8AB23E[VesTest.Common.Utils.SoftwareUpload.Strategies.PhoenixSoftwareUpload.AutoIpDetectingPhoenixSoftwareUploadStrategy] in domain [8.2.1 SWupload project.lvproj for Run] and thread 6368,
 (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
Inner Exception: System.Configuration.ConfigurationErrorsException:
 An error occurred creating the configuration section handler for GeneralUserSettings:
  Could not load file or assembly 'Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
  The system cannot find the file specified. (C:UsersbjajAppDataRoamingFirecrestFirecrest.config line 8)
Inner Exception: System.IO.FileNotFoundException: Could not load file or assembly 'Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
The system cannot find the file specified.)
in 8.2.1 SWupload.vi
Possible reason(s):
LabVIEW:  A .NET exception occurred.
There is a txt-file that the error refer to. Here is the text from it and line 8 in red:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
    <configSections>
        <section name="AutoSyncReleasePackagesSettings" type="Vestas.Firecrest.ConfigurationManagement.AutoSyncReleasePackagesSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
        <section name="CleanUpSection" type="Vestas.Firecrest.ConfigurationManagement.CleanUpConfigurationSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
        <section name="CleanUpUserSettings" type="Vestas.Firecrest.ConfigurationManagement.CleanUpUserSettingSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
        <section name="ConfigurationSettings" type="Vestas.Firecrest.ConfigurationManagement.ConfigurationSettingsSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
        <section name="GeneralUserSettings" type="Vestas.Firecrest.ConfigurationManagement.GeneralUserSettingsSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
        <section name="ShowIPSelectorSettings" type="Vestas.Firecrest.ConfigurationManagement.ShowIPSelectorSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
        <section name="ShowWelcomeDialogSettings" type="Vestas.Firecrest.ConfigurationManagement.ShowWelcomeDialogSection, Vestas.Firecrest.Common, Version=4.1.0.90, Culture=neutral, PublicKeyToken=null" />
    </configSections>
    <AutoSyncReleasePackagesSettings AutoSyncReleasePackagesOnStartup="false" />
    <CleanUpSection LastCleanUpDate="12/19/2012 11:24:23" />
    <CleanUpUserSettings PromptBeforeCleanUp="Yes" HistoricalDataOverwriteOnConnect="NotSpecified"
        TimeBetweenCleanUp="60.00:00:00" MaxDiskQuota="10737418240" />
    <GeneralUserSettings PromptBeforeExit="true" />
    <ShowIPSelectorSettings ShowIPSelectorOnConnect="true" />
    <ShowWelcomeDialogSettings ShowWelcomeDialogOnStartup="true" />
</configuration>
I have placed the file "LabVIEW.exe.config" in the LV 8.2.1 directory with this content:
<?xml version ="1.0"?>
<configuration>
   <startup useLegacyV2RuntimeActivationPolicy="true">
      <supportedRuntime version="v4.0.30319"/>
   </startup>
</configuration>
Does anyone knows what to do?
Thank in advance
Bjarne
Hi Ton
Thank you, but my problem is not switching between different versions of dotNET.
The version(4.0) I want to use seems not to work in 8.2.1.
I used this to tell LV which dotNET version to load.
regards Bjarne
Edited by Bjarne Joergensen
