Testy Posted February 19, 2013 Report Posted February 19, 2013 An example of what I'm doing: Given: [1,2,3; 2,2,2; 2,4,4; 3,1,1; 3,3,3] Output: [1,2,3; 2,3,3; 3,2,2] So that the output array has unique values in the first column, the values in the other columns being the average of the rows with the same value in the first column. The code I have right now is this: Is there a simpler way to do this? Quote
hooovahh Posted February 20, 2013 Report Posted February 20, 2013 It doesn't look like your attached any code. Yesterday there was some LAVA issues so this maybe this is to blame. In either case I've attached my go at it. This uses two OpenG VIs Remove Duplicates and Search Array. Install the OpenG Array package to get these VIs. Average Rows Same First Column Hooovahh.vi Quote
