LabVIEW 7.1.1 Released
Wolfram
Hello all,
there is a new version of LabVIEW for download on the NI ftp.
Look at:
ftp.ni.com\support\labview\updates\windows\7.1.1
LabVIEW 7.1.1 Readme
November 2004
This file contains important information about LabVIEW 7.1.1, including installation and upgrade issues, compatibility issues, and changes from LabVIEW 7.1.
Refer to the National Instruments Web site for the latest information about LabVIEW 7.1.1.
Changes from LabVIEW 7.1
Known Issues
  • 2 weeks later...
I've got some trouble when I run an executable made with 7.1. After updating to LV 7.1.1, the 7.1 executable was not running any more.
It was also impossible to install the LV run time engine 7.1 additionally to the run time engine 7.1.1. So I had to rebuild another executable with 7.1.1 in order to fix the problem.
But this is not good, because any launched application built with 7.1. may not be running any more, when updating to 7.1.1.
:thumbdown:
  • 2 months later...
I did the full mass compile like the README said, but I got this in the log:
#### Starting Mass Compile: Tue, Mar 08, 2005 9:55:35  Directory: "C:\Program Files\National Instruments\LabVIEW 7.1"  ### Bad VI:    "aequalb.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\aequalb\aequalb.vi"  ### Bad VI:    "avgv1.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\avgv1\avgv1.vi"  ### Bad VI:    "avgv2.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\avgv2\avgv2.vi"  ### Bad VI:    "cross.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\cross\cross.vi"  ### Bad VI:    "debug.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\debug\debug.vi"  ### Bad VI:    "fileread.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\fileread\fileread.vi"  ### Bad VI:    "filewrit.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\filewrit\filewrit.vi"  ### Bad VI:    "lstrcat.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\lstrcat\lstrcat.vi"  ### Bad VI:    "mult.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\mult\mult.vi"  ### Bad VI:    "tblsrch.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\CINs\tblsrch\tblsrch.vi"  ### Bad VI:    "Hue Threshold.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\examples\IMAQ\IMAQ Color.llb\Hue Threshold.vi"  ### Bad VI:    "IVI Error Converter(GetError).vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\errclust.llb\IVI Error Converter(GetError).vi"  ### Bad VI:    "IVI Error Converter(GetErrorInfo).vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\errclust.llb\IVI Error Converter(GetErrorInfo).vi"  ### Bad VI:    "VXIPnp Error Converter.vi"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\errclust.llb\VXIPnp Error Converter.vi"  ### Bad VI:    "VISA Bytes at Serial Port"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\instr\_visa.llb\VISA Bytes at Serial Port"  ### Bad VI:    "VISA Set Timeout"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\instr\_visa.llb\VISA Set Timeout"  ### Bad VI:    "Distribution Plot Indicator"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\picture\cartesn.llb\Distribution Plot Indicator"  ### Bad VI:    "Min-Max Plot Indicator"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\picture\cartesn.llb\Min-Max Plot Indicator"  ### Bad VI:    "Polar Plot Indicator"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\picture\polarplt.llb\Polar Plot Indicator"  ### Bad VI:    "Smith Plot Indicator"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\picture\smith.llb\Smith Plot Indicator"  ### Bad VI:    "Recursive list with conditional accumulation.vit"	Path="C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\Utility\recursiveDirList.llb\Recursive list with conditional accumulation.vit"#### Finished Mass Compile: Tue, Mar 08, 2005 10:04:33
Any ideas?
  • 4 years later...
QUOTE (Wolfram @ Dec 2 2004, 08:21 PM)
Can you tell me abt this frustating problem.
1) I had a working system with LV 7.1 + DSC.
2) I tried to compile and make an installer.
3) The installer did not run. Some things required.I will do them next week.
4) When I come back and run the program again from labview development environment in a usual way, it doesnt run- incompatible labview runtime. Problem - runtime is now version 7.1.1 and not 7.1. The program will not work.
5) NOW- how did the runtime automatically got changed to 7.1.1 from 7.1?
6) However hard I try, this 7.1.1 runtime does not go. The labview installer CD simply shows a large green tick and says there is a higher version runtime installed and so it will not uninstall it. It will not even give you an uninstallation option for it.
7) I have trying all I could. Removed complete labview + DSC. This 7.1.1 runtime has stuck like a leech and doesnt go. My working DSC program has gone now. Only option I see is change the hard disk.
8) Tried MSIblast also. it does nto remove it.
ANY help there? I am greatly thankful.
R N
