I want to cal VI dynamically and I put the vi in the same directory as the generated exe file, and It works. What disturbs me is that the vi's contents is  exposed to the user which is not the case I want to see. what should I do to call the VI
dynamically and its contents not been seen by my user? Thankyou.
How (and WHY) do you call the VI dynamically? And what exactly do you mean by contents?
You can remove the block diagram (or lock it with a password) to hide the code.
Removing the block diagram means that you need to keep a source copy.
Using a password is not a very strong lock.
Ton
You want to copy the VI into the directory but not have the user see the VI when they list the directory contents? You can set the hidden bit on the file in the operating system, although hiding a file from a user on their own system is a temporary thing ... they can always unhide the files and see what you've hidden.
