Intensity graph with non linear X scale
Hi
I' d like to display an intensity graph with a non linear and non regular X-scale, in other words an X-scale with time dicontinuities (see image in attachment).
I have a solution by adding a slide above the X-scale, but as I have to manage cursors, is' not very easy.
I'd like to know if someone has a better solution...
Thanks in advance
Mathilde
Because there may be several hours of discontinuity, for just few seconds of interesting signal, and my customer don't want to see these "black" zones. He wants to see at a glance all the interesting zones.
Is not just cut out the blackdata and leave a reasonable black region where you cut and after that make your own axis marker by using a property node (in write mode) and the XScale.MarkerVals[] with your own markers (any number). You might have to set XScale.UniformMarker to False.
