gleichman Posted July 30, 2013 Report Posted July 30, 2013 I've been re-purposing some older test systems only to find out that the NI's drivers no longer support some of the boards. I guess there are advantages to stand alone instruments. So, I thought about making my own stand alone instruments. I found this mini-itx board with a single PCI slot. The board has serial and network adapters that I could use as my interface. The NI board is a PCI-4060 DMM. Anybody try something like this? 1 Quote
hooovahh Posted July 30, 2013 Report Posted July 30, 2013 (edited) This will work just fine as a stand alone DMM, if you don't mind the extra cost of a motherboard, Processor, Hard Drive, RAM, Power Supply, case, and software. Depending on how slick you want it to look I would recommend a PCI riser of some kind. some thing that gives a flexible ribbon cable, or possibly just a 90 degree bend, so the DMM sits parallel to the motherboard to save space. Then you'll probably need a custom case to house it. I've never used any of these cases but here are a few that might work http://www.circotech.com/istar-s-21-mini-itx-box-computer-case.html?gclid=CPq7jqur17gCFUXNOgodTDYAPw http://www.ebay.com/itm/Morex-2766-Mini-ITX-case-w-Dual-PCI-Bays-60W-PS-/130747941410#vi-content If it were PCI-Express you could fit it in the a very tiny case, and thin motherboard, and external power, using something like this. http://www.mini-box.com/I-O-shield-and-riser-card-for-DN2800MT EDIT: I changed my mind this would look awesome with the LCD read out if you can control it. http://www.mini-box.com/M300-LCD-Enclosure Edited July 30, 2013 by hooovahh Quote
gleichman Posted July 30, 2013 Author Report Posted July 30, 2013 (edited) The motherboard that I was looking at comes with a CPU. I have memory, PSU, and hard drives from old systems. I found a mini-itx case that will allow a PCI card without the riser board. It's cheap, but a little larger than ideal. http://biz.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7838765&sku=C283-ELITE120A The total cost for the project (not including my time) is about $130. Edited July 30, 2013 by gleichman Quote
hooovahh Posted July 30, 2013 Report Posted July 30, 2013 On 7/30/2013 at 3:20 PM, gleichman said: It's cheap, but a little larger than ideal. Wow a little large? I was thinking this could be a bench top DMM and the case I had with LCD was even a little large for that at 9.5'' x 8'' x 3''. Your box is 17 x 12 x 10 (I assume inches). Still re purposing hardware in this way to make a dedicated machine is a neat idea. Oh and it might look cool if you add front banana jacks for connecting to the DMM. Quote
