Calling data from csv file
This is probably a simple problem, but I have a csv file with string values in one column and numbers in another.  For example:
Volume,    6
Diameter,  5
I would like to be able to read the first column in and come up with an array of just the strings.  I have tried using the Read Text from file into the Spreadsheet string to Array into the Index Array functions, but I cannot seem to get this string array to work out, as it just comes up with 0's for the amount of rows in the column every time.
If anyone can point me in the right direction it would be greatly appreciated.
Thank You!!
welp, like I said, it was much easier than I was making it... that's what I was looking for but couldnt seem to find a forum on it. Thanks for the help, I have just started to use LabVIEW!
