ShaunR Posted August 24, 2013 Report Posted August 24, 2013 (edited) Came across a nasty little issue today. It seems that the Mouse Events are not backwards compatible between 2009 and subsequent versions. Following is a link to a zip file that contains two VIs. One is saved in LV2009, the other in 2011. If you open the LV2009 version in any later version you get a broken wire. The 2011 version, however is OK when opened in 2012/13. If you back-save (Save For Previous Version) from a later version to 2009, you also get a broken registration reference wire when loading back up in 2009 . http://www.labview-tools.com/download_file/119/309/ . Edited August 24, 2013 by Mark Balla Quote
