really2002 Posted August 27, 2013 Report Posted August 27, 2013 (edited) I use the Labview 2012 with OPENG toolkit 4.0.1.9. Must the random number within range have the two input? for example i want to generate random with 0~1, but i hav to add the 1.0 and 0.0 to the input. other with it shows the error below: Subvi 'random number within range__ogtk.vi' required input'low' is not wired Subvi 'random number within range__ogtk.vi' required input'high' is not wired does this vi have default inputs? did i do some wrong? Edited August 27, 2013 by really2002 Quote
crossrulz Posted August 27, 2013 Report Posted August 27, 2013 If you want 0 to 1, just use LabVIEW's built-in random number. Since the OpenG function is looking for a range, it makes sense that the inputs should be required. Plus that is actually a polymorphic VI. So it needs the inputs so LabVIEW knows which instance to call. Quote
