I found them by searching the Functions palette for "gaussian", "auto power" and "harmonic". I am using the PDS, however (e.g. add-on toolsets), and it seems like the toolset used to be listed in the search results. Is there a simple way to tell which vi's are part of a toolset? Perhaps just knowing which top-level function palette is enough.
3193[/snapback]
i found the, but i can make them work.....
my vi needs to do the following things....
-DAQ Vac (220-440)......
-use that Vi to Calculate the 3dr,5th and 7th harmonic
-and display it on a chart.
im stuck at the second step, i have connetec the simulated signal to the autopower spectrun node and a secuential numeric selector at the # armonics node.... and connected the amplitude and frecuendi node to a simulate signal spot and it doesnt work..thx for ur help guys
  • 3 weeks later...
