mojalan Posted October 28, 2013 Report Posted October 28, 2013 (edited) Hi a simple but dangerous problem in my project a button with default state FALSE and mechanical action : Switch until released this button turn on/off an LED indicator. very simple example; if USER press mouse middle butten and hold it; then press left button of mouse button state change from FALSE to TRUE and it is very dangerous for me? Edited October 28, 2013 by mojalan Quote
hooovahh Posted October 28, 2013 Report Posted October 28, 2013 I think you need to learn to ask questions a little clearer, but I think I see you problem and I would consider it a bug. In LabVIEW 2011 SP1 I made a button, then set it to Switch Until Released. In this state the user should will click the button, and when they release it it will return to the state it was in. So a user should only ever have a True state when the button is down, and when the mouse button is up it should always be False. What mojalan was trying to say is if you press and hold the center mouse button (button 3) the button will change to True as if the left mouse button had been used. Then while holding the center mouse button, hold the left mouse button. Now the button will change to False. Then release the center mouse button. Now the button will change to True. Now release the left mouse button, but this time the button remains True. There are many work arounds. The first that comes to mind is use an event structure and select the "Mouse Down?" event, and if the mouse button is button 3 then discard the request for a mouse down (wire a True to the discard terminal). This will then prevent the center button from doing anything. 1 Quote
mojalan Posted October 29, 2013 Author Report Posted October 29, 2013 I will try to do that. tanks I think you need to learn to ask questions a little clearer, Quote
