Why doesn't QuickDrop call my function?
Hi guys,
I have done a function that would work with the QuickDrop window. The funcion has to be a plugin. The problem is that even though on the ShortCut list of the QuickDrop window the function apears the window doesn't call the function. I tell this because I set a break point into the function and the code doesn't stop and do nothing!
I have tested the function calling it from an external VI and it seems working well.
Is there to set a special property on the VI to let it to work with the QD?
Ok... It is resolved... It was enough to close and open labview again!!!!!
To add to this, when a quick drop function runs, it runs in a different application instance.  This may make debugging slightly more difficult.  Once you get a break point to trigger you don't really need to worry about it but I'm guessing what the issue was is that you set a break point, but it was for the main application instance, and hasn't been resaved, so when the quick drop ran the break point wasn't called in the new application instance.
