Insert the item into the LV menu
For specific applications, you can use the menu editor and create runtime menus. To find this option select the Edit>>Run-Time Menu option from the default menu.
To make an item show up in the development versions menu is possible. I know when adding the ogrsc-restart package from Open G you get a new item in the development menu. Perhaps if this is you requirement some one else can provide insight on how that is done.
Have a good day.
Randall
