shuralee Posted December 7, 2013 Report Posted December 7, 2013 Hi fellas, I am a nebwie to this forum, signed up out of despair, so please don't flame me if I ask anything stupid... I am tryign to port some good old code from Windows version of LV2010 to Linux. Got LV2013 installed nicely on OpenSUSE 12.2 workstation, but need some extra libraries to get my program to function. To my dismay I realized that the linux versions of everything are so far behind the Windoze - I find it very disturbing given the strength of Linux knowledge in a general developer community. The main problem - Tryhign to figure out how to install OpenG libraries on my system without doing it one by one (there is no LVPM for linux available for LV2013 yet, although teh year is practically gone...). Has anyone got this setup to work? Many thanks! Al Quote
candidus Posted December 7, 2013 Report Posted December 7, 2013 Try to use an older version of VIPM for Linux. VIPM isn't tied to LV versions. You need, however, a compatible LV runtime engine. The latest version of VIPM for LInux available is 2011 and should work flawlessly. Quote
hooovahh Posted December 9, 2013 Report Posted December 9, 2013 Another option, but a more ugly one, is to just copy the VI files from your Windows machine to the Linux machine. Going around VIPM is not recommended because you loose your configuration management, and the inter dependencies between installed packages. But if this is a one time thing and you just want it to work with the least amount of effort, then you can go to your <Program Files>National InstrumentsLabVIEW 2010User.lib then copy all the folders to your Linux machine. There are of course other files that VIPM can install, things like tools menu items, help, quick drop functions. VIPM can basically be used to install any file anywhere in your system so grabbing just the user.lib might not be enough but for many that is all that is needed. Quote
Michael Aivaliotis Posted May 6, 2014 Report Posted May 6, 2014 Just an update to this thread for others who stumble onto it. JKI is currently working a new version of VIPM for Linux which should be out soon. More information can be found here: VIPM for Linux Quote
