ascolda Posted December 26, 2013 Report Posted December 26, 2013 Hello everybody, my question is a really simple one. Output data in my case is numbers from 0000 to 9999. It comes in the string format and I need to display it in the number format which would always have four digits. "Decimal string to number" function deletes non-significant zeroes before number, it makes number 126 out of "0126" string. Is there a possibility to display decimal number which always has four digits? Thanks! Quote
gleichman Posted December 26, 2013 Report Posted December 26, 2013 Use "Format Into String" with a format string of "%04d" Quote
crossrulz Posted December 26, 2013 Report Posted December 26, 2013 This is sounding strictly like a display format issue on the numeric indicator. Right-click on the indicator and choose "Display Format". You can also get to this via "Properties" and finding the Display Format tab. I recommend going into the Advanced editing mode and put in "%04d". This will require the display to have at least 4 digits, filling on the left 0s. 1 Quote
ascolda Posted December 26, 2013 Author Report Posted December 26, 2013 This is sounding strictly like a display format issue on the numeric indicator. Right-click on the indicator and choose "Display Format". You can also get to this via "Properties" and finding the Display Format tab. I recommend going into the Advanced editing mode and put in "%04d". This will require the display to have at least 4 digits, filling on the left 0s. Thanks a lot, it worked! As I said it was a really simple problem. I should definitely get into formatting codes. Quote
