Excel Report generation
I am using the Report generation toolkit (v1.0.1) to generate an excel report. My vi works as expected before I create the exacutable. After I make the executable the report is not generated.
I am including the _Excel Dynamic VIs.vi from _exclsub.llb as suggested by NI.
Does anyone have any suggestions or ideas?
Thanks in advance.
java script:emoticon(':headbang:')
smilie
Did you run the exe at the same computer?
if not, check our excel activex object version.
It has to be the same like on your development machine.
3664[/snapback]
I actually did compile and run the program on the intented computer without any luck. Are you suggesting I abandon the report generation tooklit and use the excel activex instead? I thought the report generation toolkit was a repackaging of the office activex objects.
Hi Mike
I have attached a word Doc containing a few bits of info is saved recently when experiencing a similar problem, you may be aware of them but thought they might be of interest to you.
3721[/snapback]
Just thought of someting else. Did you build an installer? under the advanced tab in the installer option there is a check box to include runtime engine support for report generation. Did you check this box?
3722[/snapback]
Thanks for the suggestions. I have actually tried everything you mentioned with no luck. I guess I am going to have to do it via activex.
  • 3 weeks later...
Here are few questions:
Did the excel instance show up (either maximized,mininized or normal)?
Did you use any template to generate your report? If so, is the path a relative path or absolute path?
Is the excel instance closed after the report is generated?
3968[/snapback]
Bluej, to answer your questions: 1. Excel does not start after I compile the vi., 2. I do use a template and the path is correct. 3. As a vi the excel instance remains open. As I mentioned before, nothing happens once I compile the vi.
Here is some more information:
1. I am using a subvi in my program to generate the report. In the compiled version the subvi executes when called but excel never starts.
2. If I compile the subvi by itself as a separate program everything works just fine!
