Mercurial Central Repository Server Structure
Hello,
I'm in the process of setting up a server to serve all of our yet-to-be-created Mercurial repositories from.  Given in Hg that each project will have its own repository it seems to me that a flat folder structure is the way to go ie:
CodeBigApplication1
CodeBigApplicationN
CodeSmallApplication1
CodeUsefulLibrary1
CodeUsefulLibaryN
Although with all the applications and libraries that get created this will mean there are lots/hundreds of repositories with no sub-folder structure, I can't see the benefit of organising the repositories into sub-folders.  In fact I can only see a benefit of not having them, ie simpler relative paths when an application uses a library, no funny grey areas on whether a library should fit into sub folder a or b etc.
Any thoughts on this please? Am I missing something?
Thanks,
Martin
I think your on the right lines. In reality you are always going to use a URL to access it anyway. I think this maybe required to make it easy to have hgweb automatically serve the different repositories as you create then anyway as you can use a wildcard to describe where all of the repositories are.
One of the issues you might run into is that you develop your libraries in production.I Would try to develop the libraries in separate projects that have a build result (vip or llb) that can be used in other projects. Active relative paths into the libraries source is a nono IMHO.
