Thoric Posted March 26, 2014 Report Posted March 26, 2014 (edited) I want to clear a VI's undo history, programmatically, from another VI. I see in 2013 that saving doesn't clear the history, so my original plan to simply save my target VI somewhere isn't working. Is there a scripting technique that will obliterate the undo history?? A quick search didn't find anything. Edited March 26, 2014 by Thoric Quote
Darin Posted March 26, 2014 Report Posted March 26, 2014 Changing the password erases the undo history. 1 Quote
Thoric Posted March 26, 2014 Author Report Posted March 26, 2014 (edited) Thanks Darin. I'll try that. Presumably if I take my target VI, apply a password, remove the password, I'll find the undo history is blank and the VI remains unprotected. Cheers! Edit: it seems LAVA now thinks I'm no longer "Thoric" but "Riggy" !? Edited March 26, 2014 by Riggy Quote
Thoric Posted March 27, 2014 Author Report Posted March 27, 2014 Changing the password erases the undo history. I can't get this to work programmatically. If I manually set a VI's protection to password-protected through the VI Properties window, then unprotect it again, I see the Undo history is emptied. However, if I programmatically invoke LockState.Set with Password-protected, then invoke LockState.Set with Not Locked, the VI undo history remains in tact. Inserting a Save.Instrument makes no difference either. The Undo history always persists! Any thoughts anyone? Below is a snippet of some example code that attempts to prove that password protection of a VI clears the undo history. It creates a new VI, uses a Windows API call to simulate a standard window move operation as normally performed by an operator, then sets and unsets a password to clear the undo operation but it remains intact. (I will get the snippet up here once I figure out how!) Quote
Thoric Posted March 27, 2014 Author Report Posted March 27, 2014 Snippet included as an attachment, rather than an image. Quote
Darren Posted March 27, 2014 Report Posted March 27, 2014 If you drop a dummy object on the diagram, then delete it, without wrapping those operations in a Begin Undo/End Undo transaction, it looks like it clears the Undo history. 2 Quote
Thoric Posted March 27, 2014 Author Report Posted March 27, 2014 If you drop a dummy object on the diagram, then delete it, without wrapping those operations in a Begin Undo/End Undo transaction, it looks like it clears the Undo history. How bizarre! Yes, that works. Dropping a simple ADD function, then deleting it, vaporizes the Undo History. Any thoughts as to why? Can LV not cope with changes that aren't wrapped in an Undo transaction? 1 Quote
Darren Posted March 27, 2014 Report Posted March 27, 2014 That's right. When you're scripting, you need to use the Undo transaction methods in order to preserve (and add to) the Undo history. 1 Quote
Sparkette Posted October 2, 2014 Report Posted October 2, 2014 Forgive me if I'm missing something, but wouldn't simply closing and re-opening the VI also do the trick? Or is the undo history actually saved in the VI file unlike most programs' behavior? Quote
Thoric Posted October 3, 2014 Author Report Posted October 3, 2014 My need is to clear the "Window move" undo entry, which I'm programmatically doing after loading the vi. Hence I needed to wipe the undo history programmatically too. Quote
Jim Kring Posted June 29, 2017 Report Posted June 29, 2017 I'm looking for a way to change a visible state of a Case Structure, and (A) not have this show up in the Undo Transaction history and (B) not wipe out the undo history. Right now, if I don't create an undo transaction for the visible frame change, it wipes out the undo history :-( Quote
Darren Posted June 29, 2017 Report Posted June 29, 2017 1 minute ago, Jim Kring said: I'm looking for a way to change a visible state of a Case Structure, and (A) not have this show up in the Undo Transaction history and (B) not wipe out the undo history. Right now, if I don't create an undo transaction for the visible frame change, it wipes out the undo history :-( I don't know of a way to accomplish this. As discussed above, changing a VI with scripting requires the Transaction methods to preserve Undo history. To my knowledge you can't modify a VI with scripting, have that modification not show up in the Undo history, but preserve the previous Undo history. Quote
