Dustin Posted May 1, 2014 Report Share Posted May 1, 2014 So I'm not sure if this is the proper way to report an OpenG bug, but it seems like a good place to start. The problem is the OpenG VI "Array to Array of VData" loses cluster element names when an array of clusters is used and the array is empty. I've isolated the problem to the NI VI "Variant to Data" conversion that converts the array contained in a single variant to an array of variants. I'm frankly not sure what a suitable replacement should be but I figure that reporting the problem is a good first step. 1 Link to comment
Jim Kring Posted May 1, 2014 Report Share Posted May 1, 2014 Hi Dustin. Thanks for reporting this. I think I get what you're saying. Could you attach a small example VI that demonstrates the problem? Link to comment
Dustin Posted May 2, 2014 Author Report Share Posted May 2, 2014 Jim, here is the example VI showing the problem: Link to comment
Please sign in to comment
Sign In Now
