Can the VI Recovery Dialog Be Suppressed?
I have an automated build server (Jenkins) that uses the LabVIEW IDE to build my code every time I commit it into SVN.
This works well most of the time but every so often it gets stuck on start-up of LabVIEW because the recovery dialog pops up and waits for user input.
Is there a way this can be suppressed?
I was wondering if starting the automated build version with a separate INI file would solve this problem. Any ideas?
Heiko
Haven't tried this, just a guess. Recovery files are stored at DocumentsLabVIEW DataLVAutoSave (by default). I believe if there are no files there, you won't see a recovery dialog, so you could add a batch file that clears that directory before launching LabVIEW, and run that batch file instead of running LabVIEW directly in the automated build.
