Sparkette Posted September 11, 2014 Report Share Posted September 11, 2014 I was looking for a way to change the wire appearance of a class through scripting, and I found a property called "Wire Pens" on a class library object that does just that. Not only that, but it's possible to do things through that property that you can't do in the class properties dialog! A couple of things confuse me, however. Besides the obvious (colors, width, etc.) I've figured out that while the property accepts an array, it only works if there are exactly two elements in the array. (Otherwise it just uses the default "burgundy chain" wire.) The first one is for the inner style, and the second one is for the outer style. "Fill Pattern" is a cluster of 8 unsigned bytes, each of which determines the appearance of a single row of the pattern by its bits. I'm pretty sure all of the pattern types you can choose in the dialog are the same for every row, so it's interesting you can choose an 8x8 pattern here as opposed to just 8x1. But there's four properties whose purpose I can't seem to figure out: Mode, Style, Fill Rule, and End Caps, all of which are enums. Mode can be set to various rendering modes, like Copy, Not Copy, Exclusive Or, etc. However, of all the options I've tried, only Copy seems to work; the others just crash LabVIEW. Which shouldn't happen, considering this isn't a private property. In fact, the property node is yellow, meaning you don't even need to have scripting turned on. As for the other three, they seem to have no effect. Style contains things like Solid, Dash, Dot, etc., but it has no effect on the appearance of the line. (Yes, I even tried with Width set to 1.) Fill Rule can be "Even Odd" or "Winding", which again, doesn't seem to affect the wire appearance. Finally, End Caps can be Default or Flat, and--you guessed it--it seems to do nothing. So what are these options for? If it was a private property I'd understand if there were parts of it that appeared to have a specific purpose but didn't do anything (or crashed LabVIEW) but this is a public one, so I'd expect it to be more polished. Quote Link to comment
hooovahh Posted September 11, 2014 Report Share Posted September 11, 2014 Well I found this help on the property. http://zone.ni.com/reference/en-XX/help/371361J-01/lvprop/lvclasslibrary_wire_pens/ I was thinking this was as simple as you forgetting to read the help but the help in this case isn't very...helpful. Quote Link to comment
SDietrich Posted October 16, 2014 Report Share Posted October 16, 2014 It isn't much but the Style member of the cluster is the same type as the Style member of the Pen input to the Draw Line.vi. Maybe LabVIEW uses these routines internally to draw the block diagram? Quote Link to comment
