hi!!
using the tick count i want to calculate delay time (second) between two lines in my "table out" but the result is not what i wanted!
                 _  _
example16x16_smiley-indifferent.gif 1 | 0 |  after 6 seconds we change 1 to  2
               | 2 |6 |    after 7 seconds we change 2 to 3
               | 3| 7 |   etc...
this is my attached vi,
grateful for your help
Loom 1.vi
I'm guessing English isn't your first language but could you try to explain what you want again?  Your VI doesn't seem to make much sense.  You should probably be using the event structure since you are looking for a value change, instead of polling the change every second.  Also your color scheme is hard on the eyes.
EDIT: Crosspost
