bigjoepops Posted October 28, 2014 Report Posted October 28, 2014 I am trying to use an instrument driver I found from NI.com and I am having some issues with it. I want to put it into a source controlled location (that isn't checked in yet) but it appears that it wasn't built to allow it to be put anywhere other than the inst.lib folder. Are all instrument drivers written like this? I got the LV2012 version below. http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0203928FCCB74C96E0440003BA7CCD71 When I move it to our source controlled location I get "Warning: has been deleted, renamed or moved on disk" error messages. All I did was unzip the files from the zip file I downloaded to the source control folder. Is there a way to "install" these files to the source control folder instead of the inst.lib folder and have it work without an error message? I just wanted to check this before I spend a lot of time making the library and project find the files. Thanks. Quote
crossrulz Posted October 28, 2014 Report Posted October 28, 2014 cross post on the dark side: http://forums.ni.com/t5/LabVIEW/How-do-I-install-instrument-drivers-in-folders-other-than-inst/m-p/3036667#U3036667 Quote
