hooovahh Posted January 13, 2015 Report Posted January 13, 2015 Does anyone know where the browse property dialog is on disk? If you drop down a property node, the first item in the list is "Browse..." and clicking this will open a new dialog where properties are shown in a tree which can be selected. There is also a search feature, and a sort alphabetically. I can re-create this dialog but if it exists I'd like to just leverage as much of it as I can. I searched for "Property" under the resources folder and didn't find it. I also tried to abort all VIs in all context, when it was open hoping that would abort the dialog so I can find out where it is but that also failed. Any ideas? Quote
Darren Posted January 14, 2015 Report Posted January 14, 2015 Unfortunately, the Class Browser (both incarnations...the one you describe, and the one you see when you press Ctrl-Shift-B) is not implemented in G. 1 Quote
