Calorified Posted January 21, 2015 Report Posted January 21, 2015 Hi all, I am trying to log files to some tdms file in myRIO. I got the code setup in myRIO FPGA side and the RT vi (both attached below). I have the Real TIme code working but I can't seem to get the data-logging VI working (it tells me I have a lot of broken wires and methods not supported in target). Please take a look at the RT Current Control.vi code and see if there is something I am missing. Thank you! RT Current Control.vi Current Control.vi Quote
crossrulz Posted January 21, 2015 Report Posted January 21, 2015 Well, I am noticing you are not passing your TDMS File reference from the Open TDMS to the TDMS Write. The other thing to be aware of is where you put the file. I recommend giving this article a good read: http://www.ni.com/tutorial/14669/en/ Quote
Calorified Posted January 21, 2015 Author Report Posted January 21, 2015 (edited) Well, I am noticing you are not passing your TDMS File reference from the Open TDMS to the TDMS Write. The other thing to be aware of is where you put the file. I recommend giving this article a good read: http://www.ni.com/tutorial/14669/en/ Well, I am noticing you are not passing your TDMS File reference from the Open TDMS to the TDMS Write. Well, I made the change and still got no way around this. The other thing to be aware of is where you put the file. I recommend giving this article a good read: http://www.ni.com/tutorial/14669/en/ What exactly do you mean? I tried the home directory and the broken links are still there. RT Current Control.vi Edited January 21, 2015 by Calorified Quote
