Driver for PCI-DAS1002 card to be used with LV7.1
cmaster
hello
help needed installing PCI-DAS1002 card with labview7.1
Windows sees card, but labview does not seem to see it.
I know the PCI-DAS6000 series cards are meant to be equivalent to the NI cards, which labview
sees. Can anybody Please help?
Cheslin Ellis
Did you purchase their Universal Library that provides drivers for LabView? See:
http://www.measurementcomputing.com/cbicat...M19DA6EQRMF7X28
I do not know if their drivers allows MAX to see and configure the card, also do not know if it allows DAQMX functions support.
My personal policy is: Use National's software, then use their hardware. Saving a couple hundred $ by buying a non NI card can cost you a heck of a lot more in lost time and lack of dedicated support (and finger pointing!).
4035[/snapback]
Not a chance...DAQ functions won't work. This is quite obvious.
Will DAS develop a LabVIEW LLB to provide support for their boards in LV? Dunno!
Using NI HW with LV is straightforward, other vendors' HW may be not worth the effort.
:ninja:
:ninja:
4048[/snapback]
Thats dissapointing news. The university bought 10 of these cards and the local Measurement Computing technical support has apparently not been much help.
thanks anyway
Cheslin
In the past, Measurement Computing support consistently went out of their way to explain to me the workarounds for getting their hardware working in LabVIEW.
  • 1 month later...
