Hexadecimal String to number
Hi to all,
I just spent some time searching the forum, but unfortunately I did not found a satisfying result...
The communication to set up should be using the RS-232 interface. I am using VISA configure serial port -> write -> read -> close (LW 7.1)
I got an auto-correlator which returns me 256 equidistant ACF-values as a row of 512 Byte with the following structure:
1.byte
00(hex)...FF(hex)
2. byte
00(hex)...C0(hex)
511. byte
00(hex)...FF(hex)
512. byte
00(hex)...C0(hex)
For that I am using the VISA read, which gives me the correct 512 bytes after sending the "GetACF" command.
By placing an indicator at the output of the VISA read and changing its properties to "hex" I see the right string.
For further processing I need to convert it into numbers. Using the "Hexadecimal String to number" does not seem to work.
For sure, it is my fault, but I already tried different number representations (which is the only thing to modify)
Here the first 10 bytes of my signal:
04E3
04EE
04FD
04F4
04FA
Using a probe data between the VISA read (read buffer out) and the Hex string to number does not indicate me the hex string, but any symbols.
Could this be the problem???
Thank you in advance for any hints.
Hi to all,
finally I am using Unflatten from String in a While Loop.
It works fine, just that HEX numbers above Axxx appear negativ :-\
Also with the Type Cast, they become negative, although I am using a 16bit word as type.
EDIT: ok, now it works fine. I just had to change the type to "unsigned Word" :D
Anyway, thanks a lot for your help :)
  • 1 year later...
Hi to all,
1.byte
00(hex)...FF(hex)
2. byte
00(hex)...C0(hex)
511. byte
00(hex)...FF(hex)
512. byte
00(hex)...C0(hex)
04E3
04EE
04FD
04F4
04FA
How would you create the string that you send using VISA that represents an integer of a number between 1 to 5.
is this correct before converting to hex?
I used this string before converting to hex. Is this format correct for sending a message of a integer?
0x00 0x09 1 1 2
