Stormshadow Posted March 17, 2015 Report Share Posted March 17, 2015 Hello,The 34401A is not longer available in Canada. We need to change and use the 34461A as a replacement and we are having trouble with the peak-to-peak measurements (We are using LabVIEW).We use the peak-to-peak option while reading a communication line in order to get the min and max values. The code:Visa Write34410ACONF:VOLT:ACVOLT:AC:PEAK:STAT ONINITFETC?Visa ReadVisa WriteFETC:VOLT:AC:PTP?Visa ReadThis code no longer works with the 34461A. Reading the AC will only give the RMS values. We dont really care how to get the min-max of the communication channel, as long as it is in a respectable time (10s at most...). Reading the signal with DC is not fast enough. The communication signal is ±100mv. We verify the min-max range to be around 200mV.Thanks Quote Link to comment
