ensegre Posted May 1, 2015 Report Share Posted May 1, 2015 (edited) On my laptop, I just discovered that LV2014 (but not 2011SP1 or 2013) segfaults at launch, even before the splash, if I connect to my institute via VPN, while it works and worked all the time if I'm just linked to WAN. Haven't seen that before, I wonder if it has anything to do with a latest ubuntu update. Any idea why that would happen? $ labview & [3] 7297 [1] Done labview owner@xxxxx:~/Desktop/yyyyyy$ LabVIEW caught fatal signal 14.0 - Received SIGSEGV Reason: address not mapped to object Attempt to reference address: 0x(nil) [3]+ Segmentation fault (core dumped) labview with ddd I see an uninformative backtrace: ETA: just upgraded to 14.0.1 (spring 2015) and the problem vanished.... Edited May 1, 2015 by ensegre Link to comment
auralius Posted October 7, 2015 Report Share Posted October 7, 2015 This also happens to me. It happens when the VPN is active. I am using Ubuntu though I know Ubuntu is not officially supported by NI. It will be interesting to know if this also happens with Redhat Linux. Link to comment
ensegre Posted October 7, 2015 Author Report Share Posted October 7, 2015 Since the day I upgraded I haven't seen the problem any further, so perhaps that would be your best option too. It is ubuntu 14.04 here. Link to comment
ensegre Posted May 27, 2022 Author Report Share Posted May 27, 2022 (edited) Seven years later, another incarnation of VPN and ubuntu 20.04, still the very same problem hit me again for LV14.0: immediate crash if started while Checkpoint snx is running, no crash if snx is started afterwards Not with LV2019, not 2021 in the same conditions... Since I need specifically LV14 for a legacy project, I have to remember where I put the 14SP1 installation media. Edited May 27, 2022 by ensegre Link to comment
Please sign in to comment
Sign In Now
