andywcchung Posted June 1, 2015 Report Posted June 1, 2015 Hi all I am new for labVIEW and myrio. There are some problem. I connect the X-CAN to CANbus device and only get one or two ID. My CAN device can output 22 id . if i use cRIO CAN module, i can get all data. Where is the problem? Is there any solution to solve this? Thanks Andy Quote
hooovahh Posted June 1, 2015 Report Posted June 1, 2015 What IDs are you reading, what IDs are you missing? You didn't post any code, but even if you did I might recommend contacting Stratom. They likely have an example that is made to just read all data and display it. Is is possible the device is setup to only read standard CAN messages and is missing extended ones? Quote
