Excel range conversion
Hi everybody,
I found a Vi that converts indexes to Excel range on http://forums.ni.com/ni/board/message?board.id=170&message.id=84295&requireLogin=False but I can't find the reciprocal, i.e how to convert row and column indexes of an array (numerical) to Excel row and column format (A1, etc.)
It should already exists so if someone knows the appropriate VI...
Maybe just a VI that provides the column (or row) names from the column (or row) number is enought.
Thank you in advance.
bim
Hi everybody,
bim
4161[/snapback]
In the LabVIEW example finder "communicating with external applications/activex/excel/write table to xl.vi" there is a sub vi called "Row Col to Range Format.vi that takes care of this.
I hope this helps!
:thumbup:
OK, thank you all!
jbrohan, I'll test your VI and (if necessary) modify it. Be sure I 'll return it to you as soon as possible.
Thanks again, have a good day!
bim
  • 6 months later...
OK, thank you all!
bim
No problem...everything's running well.
Thank you again! :thumbup:
