user interface
I want to build a user interface which ask the user for username& password. I would like to know how can we check this username&password combinations?. can we reference to a file which has all the comibnations.
bye
karthas
You can make a simple password pop-up window by using the Prompt User For Input VI, it is an express VI on the Time & Dialog controls. You can configure it to return a string to your VI, then compare it to the actual password.
You could use the File I/O VI's to make a password file, and read it into the VI before you prompt the user, so the password is not actually stored in the VI.
4170[/snapback]
maybe you want some encryption for your username/password files ?
then you can use this very simple XOR-"Encryption", which makes the text at least "unreadable" 2 humans, but it will not withstand any brute force cracking ;-)
best regards,
cb
Download File:post-885-1110525035.zip
