Unit label inconsistency
The editor doesn't seem to check units consistency on a few of the array primitives.
For example, an array of doubles with units of 'Hz' can be wired to an 'Insert Into Array', then a scalar double with units of 'psi' can be wired to the element terminal of the same primitive. No complaint from the editor; when the VI is run, it appears that the base unit values are used to perform the insert. (Incompatible units also includes the case where one input carries no units.) The primitive 'Replace Array Subset' seems to behave similarly.
Shouldn't the editor flag the VI as broken? :unsure:
Dave
  • 7 months later...
Dave
LV6.1 flaged this as an error. This bug is new to LV7. Anyone know what LV8 does?
WDC
