How to delete plots from graph
I've been trying to find a method to remove plots from my XY graph. Here's what I don't mean:
- change the amount of plots shown by reducing the size of the array that connects to the terminal or Value property node
- change the amount of items shown in the legend by setting Legend / Number of rows.
When I open the properties I see this:
And when I run this I get an array with 3 elements: Plot 0, Plot 1 and Plot 2
How do I delete Plot 2 from that list without replacing the actual XY Graph with a new one and never pull the legend down to show 3 plots?
The Array constant Wired to the XY Graph is not empty. The clusters have empty arrays but the array of clusters is not empty.  I am guessing there are three elements within the array, you will need to delete one. then run the code.
Craig
Craig, unfortunately it's not that easy. That array is empty.
Maybe I phrased my original post badly. Here's what I mean to say:
These are the suggestions users usually get when asking a similar question. I've tried those and they don't give the result I'd like:
Hi Thomas,
I thought you were asking how to change this, sorry misunderstood.
I have come across the situation where the number of Graphs visable on an XY plot sticks to the last number seen by the plot.  I also did not find a way of changing this unless I was to re-run the code presenting the Graph with a different number of plots.  Seems there is a need to be able to edit this as you suggest.
