LV Developer Posted September 28, 2015 Report Posted September 28, 2015 Hello, Can anyone help me. I want to unzip the file that is password protected in labVIEW. It is not possible by using Unzip.vi. My OS is Microsoft 10, and I am using labVIEW 2014. Thanks in advance. Quote
hooovahh Posted September 28, 2015 Report Posted September 28, 2015 This isn't a working solution but it might help. I would use 7-zip, which has a command line utility, and a DLL. http://lavag.org/top...rs/#entry101116 There someone asked about zipping a folder of files in a way that wasn't supported so I suggested using 7-zip in a command line to get the function needed. You can look at the code and modify it to extract the zip using a password. Quote
