alondono1 Posted November 2, 2015 Report Share Posted November 2, 2015 i am new to this site so hello community, im sure this is rather simple to someone with experience. i tried looking at the previous post but i dont have enough exprience with the software to follow properly. Using a while loop build a 14 element array first 2 elements are 1 and the last 2 remain at zeroes the rest of the elements will be the sum of the previous 2 with a pause of a second. anything helps Thanks Jason Link to comment
hooovahh Posted November 2, 2015 Report Share Posted November 2, 2015 Great what have you tried? Post a VI with your best attempt. What specific requirement are you having an issue with? Have you tried the free training links found here (at the bottom) https://decibel.ni.com/content/docs/DOC-40451 Also what does this have to do with OpenG? 1 Link to comment
alondono1 Posted November 3, 2015 Author Report Share Posted November 3, 2015 i probably posted this on the wrong section Link to comment
Please sign in to comment
Sign In Now
