Hi all
I have  plan,to add one new LabView exe program compiled in LV2015 on one PC, where there is already one LabView exe program compiled in LV2011.
Have you ever encounter some problems or limitations with two runtimes running at same time.
Just for detail, I can't upgrade exe 2011 because i don't have sources.
Eric
The runtime engines will coexist well together.  Some drivers sets will not - be sure you can find drivers supported by both engines, if you need the same functionality on both builds, as (afaik) you can only have one set of drivers for each instrument type (e.g. XNET, DAQ, DMM, etc...)
