prettypwnie Posted July 3, 2016 Report Share Posted July 3, 2016 I'm using a MySQL database and it has some columns of the datatype DATETIME. When I store data in these fields, I format my timestamps into a string of the YYYY-MM-DD HH:MM:SS format and it works just fine. However, I'm having a problem when I get the DATETIME values back out of the database. I'm using the DB Tools Select Data VI and then Database Variant to Data to convert it into a string (it won't let me convert directly to a timestamp). The problem is that the string I get is the date and time, formatted according to my system date format, which for me is MM/DD/YYYY II:MM:SS p. I want it to stay in the YYYY-MM-DD HH:MM:SS format, so I can use that format to convert it back to a timestamp. I've tried changing my system date format, and that fixes the problem, but I'm afraid it's not a very robust solution. I don't want my program to break if I try to run it on someone's computer that has a different system date format. Does anyone have any ideas of how I can make it always output the same format? Thanks! --Hope Quote Link to comment
LogMAN Posted July 3, 2016 Report Share Posted July 3, 2016 I don't have experience with MySQL specifically, but it should work similarly to MSSQL on this behalf. Check these two sources: http://www.w3schools.com/sql/func_date_format.asp https://dev.mysql.com/doc/refman/5.5/en/date-and-time-functions.html#function_date-format Your query should be something like this: SELECT DATE_FORMAT(column, "%Y-%m-%d %H:%i:%s") FROM table_name; Use the Scan From String function to convert the string into a LabVIEW time stamp: Quote Link to comment
prettypwnie Posted July 3, 2016 Author Report Share Posted July 3, 2016 Thanks so much for your response! I just tried what you said of typing in a query with the DATE_FORMAT to the database in workbench and it works great, it returns the date in whatever format I specify. What I'm confused about, though, is how do I get that from LabVIEW? The DB Tools Select Data VI doesn't have a date format input or anything where I think I could put that kind of parameter. Quote Link to comment
LogMAN Posted July 3, 2016 Report Share Posted July 3, 2016 You can execute any SQL query using the Execute Query VI from the Advanced palette. Here is an example I just put together (untested of course): 1 Quote Link to comment
prettypwnie Posted July 3, 2016 Author Report Share Posted July 3, 2016 Oh, this is great, it works perfectly! I did see the Execute Query VI there on the advanced palette, but I couldn't figure out how to use it because I didn't know what to do with the recordset reference, so this is exactly the example I needed. Thanks so much! Quote Link to comment
