JKSH Posted July 14, 2016 Report Share Posted July 14, 2016 I have a project structure like this: <ProjectRoot> (Project.vipb) Examples Example1 Example2 Source Cpp LabVIEW LVClass1 (Method1.vi) LVClass2 (Method2.vi) The auto-generated Functions Palette is structured like this: [Functions] >> [Company] >> [Project] >> Source >> LabVIEW >> LVClass1 >> Method1.vi [Functions] >> [Company] >> [Project] >> Source >> LabVIEW >> LVClass2 >> Method2.vi However, I would like a simplified palette structure like this: [Functions] >> [Company] >> [Project] >> LVClass1 >> Method1.vi [Functions] >> [Company] >> [Project] >> LVClass2 >> Method2.vi Is there a way to get VIPM to auto-generate the palette that way? I can think of a few workarounds (restructure my project, or add every palette folder manually) but I'm hoping I don't have to resort to them. P.S. Sorry if this is the wrong place to post this, but I'm unable to post on the JKI forums Quote Link to comment
LogMAN Posted July 14, 2016 Report Share Posted July 14, 2016 The palettes are auto-generated based on the source directory defined in the Build Information tab. I suppose it is set to <ProjectRoot>, so change it to <ProjectRoot>/Source/LabVIEW and the palettes should be correct. 1 Quote Link to comment
JKSH Posted July 15, 2016 Author Report Share Posted July 15, 2016 6 hours ago, LogMAN said: The palettes are auto-generated based on the source directory defined in the Build Information tab. I suppose it is set to <ProjectRoot>, so change it to <ProjectRoot>/Source/LabVIEW and the palettes should be correct. D'oh! So simple. Yep, that did the trick. Thanks! (I miss the old "Mark as solution" feature from the previous forum) Quote Link to comment
JKSH Posted July 15, 2016 Author Report Share Posted July 15, 2016 Darn, I just remembered why I had the *.vipb in the root folder in the first place: I wanted the Source folder to contain my library's API and implementation only, but the Examples are neither so I put them in a separate folder. Unfortunately, VIPM doesn't let us include things in the package if they're outside the Source Directory (which means I now can't have examples in my package). I'll downgrade VIPM to see if I can easily modify the *.vipb's XML data after the palette is auto-generated. If not, I guess I'll just have to move my Examples folder... (If you can think of a nicer idea, I'm all ears!) Quote Link to comment
LogMAN Posted July 15, 2016 Report Share Posted July 15, 2016 I have made the same experience in the past, tried many things and finally moved the examples folder under LabVIEW sources for a couple of reasons: The example folder contains LabVIEW VIs only (in my case that is), so it makes sense to put them under LabVIEW sources. API sources can be arranged differently than "regular" projects, if there are good reasons for it. However this should be made standard for all APIs! Depending on how many configurations you have to manage (about 20 with regular changes in my case), it is less painful to just accept the standard behavior, than trying to convince VIPM to do otherwise. Or more accurately: You can do this with VIPM, but it is a pain to do for every single package, let alone multiple projects! Re-writing the *.vipb requires you to do it every single time, which you will eventually forget! You could potentially use the VIPM API, if you REALLY want to do things your way (never used it though) Quote Link to comment
