cpipkin Posted September 1, 2016 Report Share Posted September 1, 2016 Hello, I'm using the subVI "String Selector.vi" to select the frequency I need to tune to. The "Instrument Tuner.vi" determines whether or not the instrument's frequency is sharp, flat, or in tune. When I run "string selector.vi" independently (in a while loop or running continuously), the output / "desired fundamental frequency" updates quickly and correctly. However, now that I am using it within the Instrument tuner VI, it does not update. My goal is to get the "Desired Fundamental Frequency" to update if i click on a different instrument / string the same way it does when I click octave1, octave2, or octave3. Any ideas as to how i can get the desired fundamental frequency to update correctly? Thanks! instrument tuner.vi String Selector.vi Quote Link to comment
eberaud Posted September 1, 2016 Report Share Posted September 1, 2016 Well the string selectors listboxes of instrument tuner.vi (Cello Strings, Guitar Strings, and so on) are not related to the ones inside String Selector.vi at all... You need a way to pass their values to String Selector.vi otherwise String Selector.vi will keep using their default value (index 0). 1 Quote Link to comment
cpipkin Posted September 1, 2016 Author Report Share Posted September 1, 2016 (edited) @Manudelavega -> thanks! I thought they were connected for some reason. I solved it by giving each listbox a slot on the pattern terminal. Edited September 1, 2016 by cpipkin Quote Link to comment
