art Posted April 6, 2005 Report Share Posted April 6, 2005 Hi all Complete n00b here. I need to install a USB joystick, and the ni.com has the VI I need to get it up and running (I hope). The only thing I get is one file missing, namely "load velocity override.flx", and I have no idea where to look for the file. Can someone help me on this? Where are the .flx files generally stored? Thanks a lot. Quote Link to comment
nightdweller Posted April 6, 2005 Report Share Posted April 6, 2005 Hi allComplete n00b here. I need to install a USB joystick, and the ni.com has the VI I need to get it up and running (I hope). The only thing I get is one file missing, namely "load velocity override.flx", and I have no idea where to look for the file. Can someone help me on this? Where are the .flx files generally stored? Thanks a lot. 4457[/snapback] You can search for it... if you have the ni motion toolkit. It's under Ni Measurements->Motion Quote Link to comment
Gepponline Posted April 7, 2005 Report Share Posted April 7, 2005 ...ma ciao! my suggestion is to reinstall all the motion utility using the Device Drivers CDs. In the past i had some similar problem due to the installation of the motion toolkit over the motion VIs include in the Device driver CDs. The "load velocity override" VI is an Advanced Trajectory Control VI. It must be in "NI Measurement->Motion->trajectory control->advanced" palette. You can load your VI ad then replace the error with this vi! Quote Link to comment
