Tetris in LabView problem with move blocks
Hello.
I try to make Tetris in LabView.  I have problem with stop blocks on the last field and move blocks left and right.
Does anyone have an idea how to solve it?
Tetris4.vi
Edited by Kassia
Collision detection?  Basically each block (normally only one falls at a time) will keep incrementing until a stop condition is seen.  In your case it will be from the lowest block hitting the floor, but when the game goes on you could have any block hit another block forcing the whole 4 pixel object to stop moving down.  You already have in a shift register where your objects are, so I'd suggest doing something like shift down, then count the number of Trues in the array.  If they are less than the number of Trues before the shift then you know you shouldn't perform the shift and should revert back to where it was.  There are examples on the web of doing tetris in LabVIEW and LabVIEW even used to ship with a version of it in the example finder.  I can't seem to find it in modern versions but if I do I'll post it.  Here is one discussion with several demos.
https://forums.ni.com/t5/LabVIEW/Tetris-in-Labview/td-p/265716
  • 9 months later...
