Listbox Shortcut Menu
I did not ask this.
To the "listbox" list, I dynamically add plugins and run in a subpanel.
Running a randomly chosen plugin should deactivate listbox shortcut(right-click) menu only on this row.
Without an example VI, and more explanation in the post (like "listbox" isn't mentioned anywhere in the description) I wasn't sure what you were referring to.  The easiest way of doing this is with an event structure and the Mouse Down? event.  Here you can use the Discard? input, and if the right click mouse button was used, and the selected item is one that should be ignored, discard the click and no menu will come up.
