Time
Hi!
I will read out my start time and my end time of the vi.
The outcome of this is the durability.
I read the start time with "get date/time in sec" wired this with "format date/time string" (%H.%M.%S) and show this in a field (string).
Same with the Start date ("format date" %A, %d.%m.%y).
I wired the stop button of a while case with a case structure and so I try to get the end time/end date.
Again with "Get date/time in sec" - "format date/time string"- field (string).
Now my problem, the period.
I tried out subtraction. But there is a problem with the format. I must change the string into number. "String to byte array" won't work (I only get #8 as value) or I have done something wrong.
Maybe there is a simple solution for my problem :headbang:
  Sarah83 said:
Hi!
4582[/snapback]
Try using the Get Date / Time in seconds function for the stop and start times. You may then subtract the two and display the total time with a numeric indicator. Set the indicators property
  regisphilbin said:
Here's another example getting the time from start of run to end of run.
obtain the start time using "Get Date/Time in Sec".  Then run your program.  On the close of the program,  read the end time again using the same "Get Date/Time in Sec",  Subtract the two and your done....
Regis
4590[/snapback]
Regis & didierj both have it.
Here is a modification of Regis's example that provides your start and stop time.
Download File:post-274-1114112558.vi
