That Whacky timestamp datatype
The new Timestamp data format is cute until you start to use it. The problem is performing any math on the data resolves it to DBL number.
The crux of the problem is once it's a DBL - the only method to convert it back to a timestamp leaves off the msec counts. Here is a diagram shot of a typically application and how the problem really makes this a pain..
This clearly showns the timestamp datatype was not thought out completely...
post-37-1114395645.jpg?width=400
Jack,
numeric cenversion palette contains a "To Time Stamp.vi" that converts a number to a time stamp.
You don't have to make the string conversion.
just my :2cents:
Manfred
maybe you can solve your problems with the timestamp with this vi ...
it's in german, so you have to translate it in your language
best regards,
cb
4621[/snapback]
:thumbup: Nice tool, could it find its way into openG?
A few more issues on timestamps:
1. Someone posted the "Waveform Attribute" function is not used to modify the timestamp.
> Reading the Help for it - says it does.
2. I missed the "Convert to Timestamp" function because it's clearly in the wrong palette! It should be in the
Time and Dialog" Palatte. It is located in the 'Numeric -> Conversion" palette.
>Anyone who disagrees: needs to justify why the "Seconds to Date and Time" is in the 'Time and Dialog" palette - is it not a numeric conversion?
Regards
Jack Hamilton
