Using grow/shrink function on single structure
Anyone know of a way you can do a ctr+drag on the block diagram (adding or removing space) that only impacts the current structure?  I find myself wondering if this functionality exists often enough I thought I'd ask.
Basically if you have a for loop inside a case structure is there a way to do a drag inside the for loop and grow that structure without impacting the case structure size or position?
Thanks,
Tim
You can turn Auto-Grow on for that loop. Then select any item in the structure and use the arrow keys on the keyboard to push that item past the edge of the structure to make it grow. Not quite the same thing, but maybe close enough?
