Unable to install OpenG LabVIEW ZIP Library & OpenG Port IO (both v4.0.0-2)
I'm trying to install the OpenG ToolKit under LV2015 (32-bit), but I get a couple of packages that fail to download
http://www.jkisoft.com/packages/packages/oglib_lvzip/oglib_lvzip-4.0.0-2.ogp
http://www.jkisoft.com/packages/packages/oglib_portio/oglib_portio-4.0.0-2.ogp
Thing is they're already installed on my present PC, just corporate rules say I have to be upgraded to a newer PC, which I'm now trying to set-up..
64-bit versions appear to be available, just not the 32-bit.
I get the following errors;
Quote
Main Package Name: OpenG LabVIEW ZIP Library v4.0.0-2
Package Name with Error: OpenG LabVIEW ZIP Library v4.0.0-2
Error Message: VIPM could not download the package oglib_lvzip-4.0.0-2 from the remote server.
Error Code: 59
Error Source: Wininet Network Error: HttpQueryInfo;
Quote
Main Package Name: OpenG Port IO v4.0.0-2
Package Name with Error: OpenG Port IO v4.0.0-2
Error Message: VIPM could not download the package oglib_portio-4.0.0-2 from the remote server.
Error Code: 59
Any suggestions welcome.
Kev
Edited by fish65
If you already have the packages installed on your present PC, you can retrieve them manually from the cache directory: <ProgramData>\JKI\VIPM\cache
This is just a temporary workaround... maybe you can notify JKI on the VIPM forum if this issue persists.
