ayoub11n Posted August 3, 2018 Report Posted August 3, 2018 Hello Everyone, I am new to Labview and am trying to control a distorted sine wave. the set up consist of a sine wave signal gets amplified in which an EMF is induced in the secondary voltage by the voltage and current flowing through the primary. at some point the output voltage wave form gets distorted. my approach is to modify the input such as the output remains sinusoidal. any though how to tackle this problem will be appreciated Quote
Benoit Posted August 9, 2018 Report Posted August 9, 2018 Are you new to electronics to? if not, do with labview the same way you will do with electronic component. OR if i understand well, just create an array of element with the same dimension of your original sine wave. In this array add random value centered of not to 0. then add the two array and display it in graph to see the results. Benoit Quote
