Write/Read data between two exe application
Hi all
I would like to Write/Read data between two exe application.
I can use Notifier operation to Write/Read data between two Vi, but I can't use it after I build *.exe.
Dose anybody knows how to do this or any example?
Thanks in advance.
Hi all
Thanks in advance.
4749[/snapback]
every *.exe is running in its own runtime environment, with its own memory, etc ...
if you are experienced with windows programming you can use the windows messaging system via the win-API or you can use TIP/IP or UDP ...
cheers
cb
